Hi, I was getting bothered by several mentions I've seen in forums suggesting that the reason to toe-in waveguides was to minimize some kind of defect, so during some down time I wrote up a small article with diagrams and discussion about the real reason for toe-ing in. Not because we have to, but because it's the only speaker type that can really take advantage of toe-ing! It's in the DIY Sound Group "Articles" section at http://www.diysoundgroup.com/forum/index.php?action=articles;sa=view;article=1 ================= edit: Here is the direct link to the pdf file of the article itself. url=http://libinst.com/PublicArticles/Setup%20of%20WG%20Speakers.pdf -Bill Waslo
Thanks for the nice article, Bill. Your mention of time/intensity trading may have saved me from making a setup mistake. I was thinking the easy way to set toe-in would be to just move sideways across the listening area and adjust for the most even SPL reading on an SLM. However I had forgotten about the time part so would not be right. Any idea on the relative importance of time vs. intensity in determining the perceived loudness (pr should that \be directionality)?
Not sure if Wayne Parham likes links to his Pi Speakers papers, but they are wonderful resources of information. JSS
Bill, thanks for that article. It's the most pithy summary of best practices for front speakers that I've seen. Do you mind if I put a link to it on my newish blog (seriousaudio.blogspot.com)? Since it's hosted by your company, I thought I'd ask before doing it.
It's up. http://seriousaudioblog.blogspot.com/2012/04/great-article-setup-of-controlled.html Comments welcome, of course. And good idea about driving traffic here. I included a link.
I have seen them linked on other sites, so here goes: http://www.pispeakers.com/Pi_Speakers_Info.pdf http://www.pispeakers.com/Speaker_Crossover.pdf http://www.pispeakers.com/Speaker_Crossover_Lab.pdf And a general JBL Reference: http://www.pispeakers.com/ssdm_99.pdf If you want to glean a ton of information about all things speaker quickly, do a search on pispeaker's forum with only Wayne Parham as the user to filter by and no subject. SOLID GOLD. JSS
Agreed. A great read for those of us who've never owned (and are planning to) constant-directivity speakers.
Fantastic article, Bill. I'm not sure why I hadn't realized/understood the time alignment aspect before now, but it makes a lot of sense after reading that. Seriously, Thank you. Steve
Hi, I've updated the article (and gave some credits for the ideas included in it). url=http://libinst.com/PublicArticles/Setup%20of%20WG%20Speakers.pdf Bill
Tannoy has been recommending crossfiring since at least the 70's. http://www.hilberink.nl/codehans/hpdtech.zip
Excellent lay explanation of the effect! The effect to work requires constant narrow(ish) horizontal directivity, so it would be nice if Don Keele could be mentioned in the credits. And maybe also the JBL 4430 team?
Sorry for the thread necromancy, but this seems the best place to answer my question. If planning to toe-in as the articles above suggest, would it be beneficial to separate the controlled directivity device of a loudspeaker from the non-controlled device? I.E. - allow a waveguide to be toed-in and the woofer aimed directly at the listening position? I know that lower frequency sound doesn't beam like high-frequency, but would a woofer toed-in as heavily as the waveguide be affected detrimentally if crossed over at 1500Hz or lower?
The woofer in these kinds of speakers is chosen large-ish because that gives it a matched directivity at the crossover frequency, so the speaker can sound more like a single source rather than having an abrupt change in directivity at the crossover point. You want it to do what it does, directivity wise, that's part of the design. At lower frequencies, the directivity gradually decreases rather than all at once. So, leave the woofer toed-in as well, to keep the off-axis sound better matching the on-axis sound.
Thanks! That makes it much easier to build, too. I was assuming that it would already be discussed if it was a worthwhile experiment but I had to ask.
The document doesn't mention any specific angles. And the toe-in, in the setup with large toe-in, seems to be less than 45 deg (from the line joining the 2 speakers) Assuming on axis FR is flat, wouldn't 45 deg toe-in be enough ?
