Design to replace Paradigm ADP-170 di-poles
Discussion in 'General Topics' started by sslv2pwned, Jun 2, 2013.
  1. I have a pair of blown Paradigm ADP-170 di-poles for my rears. I thought about replacing the drivers, but am wondering if building something would be better. The problem is my room. The di-poles work well in my room because I can mount them high on the side walls. I don't really have the ability to mount speakers on the back wall.
    Is there a design here that would be better than my Paradigm's and be good to use on the side walls - keeping in mind that these are my rears? I would also like to be able to use my AVR to power them - 140w per channel.
    AVR: Denon AVR-4311CI
    Fronts - B&W DM 603 S2
    Center - B&W LCR6 S2
    Rear - Paradigm ADP-170
    Subs: Currently building two DIY SG 18" subs
  2. Any of the kits should do it for you. Don't you want your surrounds to the sides. Maybe the alpha 8 kit? What's your budget?
  3. I guess I am calling them by the wrong name. It's a 5.1 system. Aren't the rears normally on the back wall behind the listeners in a 5.1? My bi-poles are mounted on the side walls in-line with the main listening position.
    Budget is open. I was looking at the Fusion-10 Max, but they may look huge on my walls. Right now I am looking at the Alpha-8 Minion.
    I will eventually build a pair of Fusion-15 Sentinel to replace my fronts - B&W 603's towers.
  4. http://www.thx.com/consumer/home-entertainment/home-theater/surround-sound-speaker-set-up/
    Scroll down to 5.1.
    I think you're ok. Pick a kit. Any kit. Step right up to the diysoundgroup experience, where all your needs are met. Hehe. What ever fits your size constraints and budget is going to do well I think. I like the alpha 8 based on its paper work. I've never used it.
  5. I was addicted once I received my 4cf flat pack from Erich. :)
    Which of the smaller kits have you heard?
  6. One more question... I'm debating between the Alpha-8 Minion and the Fusion-8 Alchemy. However, I'm wondering how these will work with my current B&W LCR's? I want to eventually replace them with Sentinels, but I don't know when that will be. What do you think?
    Thanks for all the help!
