Mixing different DIY Sound Group speakers?
Discussion in 'General Topics' started by mellowjammer, Mar 28, 2015.
  1. I am considering building Fusion 4's for mains, an 88 special for center, and Volts or Concentrics for surrounds. Any issues with this approach? BTW I've already built 2 subwoofers...each containing 4 Dayton Audio RSS460HO-4 18" Reference HO Subwoofers in sealed cabinets. I'm also considering building a Mid Bass Module to bridge the gap between the subs and the Fusions (60-150 Hz or so). Any problems using these different models together and any suggestions for MBM?
  2. Seems like that should be ok. All front speakers to use SEOS waveguides, surrounds don't have to match and are better off with wider coverage too.
  3. Based on your plans, maybe you should shorten your forum name to "Jammer", 'cause the "Mellow" part just doesn't seem to fit!
    Mike
