The AlTi, a DIY 2-way bookshelf speaker design.
Discussion in 'DIY Speakers and Subwoofers' started by Matt Grant, Aug 15, 2017.
  1. I had purchased the newer black coned Hi-Vi M5N-B a little while back, finally swapped one into on of my AlTi speakers and tested it against the original M5N. The frequency response overlaid nearly perfect, so those are a drop in swap for this design if you like the look of the black woofer cone over the original M5N's light copper/gold color.
    Added some new photos of that woofer on the few posts.
  2. Hi Matt,
    Thank you for this design, I am currently looking for my first DIY speaker project and this one looks very promising. I was originally considering the C-Note kit but the AlTi looks like should sound better.
    I'm slightly worried about this part of your description :
    I going to be using them in my living room, where I'll frequently be more than 20 degrees off axis. Should I except an audible degradation in higher frequencies in this case ?
    My current amp is a small class D so I'll add the resistor to the crossover. I read that C-Notes don't play well with class D amps (notable rise in HF). Should I expect similar issues with the AlTi or is the resistor going to help with this issue ?
    Thank you for your patience !
  3. #28 Matt Grant, Apr 18, 2025 at 2:06 PM
    The extra rolloff in that range doesn't result in any kind of drastic change in the balance or timbre, it's just a subtle decrease in some of the sparkle or air in the treble. It won't be too different then many regular dome tweeters off axis.
    The resistor prevents a capacitive load in the ultrasonic range which many class-D amps don't play nice with causing audible distortion, noises or shutdown issues. This is separate from the frequency response variability issues certain class-D amps have with differing load impedance.
    I did test the AlTI among several other speakers in some measurements looking for the frequency response issues of class-D amps, and it shows basically any speaker design that does not have a flat impedance and phase over the top two octaves will result in some form of response irregularity on any class D amps that are susceptible to that issue. Unfortunately that does include the AlTi.
    Here is a link to that testing I did:
    https://www.mtg-designs.com/tips-tr.../amp-frequency-response-variability-with-load
