Volt 6 in wall
Discussion in 'General Topics' started by WarrenBerry, Aug 12, 2015.
  1. WarrenBerry
    WarrenBerry Just joined the party
    Looking to build a cabinet to fit sealed volt 6s in wall. Of course it would have to be 14.5" wide and 3.75" deep but how tall?
    I Realize the driver would sit proud. I was planning on mounting a flange similar to the 1/2" rings mtg90 had on the construction thread to allow the driver to stick out enough
    I am planning to build a sealed room and would like to do boxes to stop sound from seeping upstairs.
  2. Matt Grant
    Make it just tall enough to fit the driver, 6-6.5" if you can. It needs very little airspace. Fill the chamber with fiberglass or poly fill and make sure it is in there somewhat dense to the sides. I would recommend a crossover no lower then 100hz if you plan on playing things loud.
  3. WarrenBerry
    Thanks man
