Volt-6 T-S parameters
Discussion in 'General Topics' started by noah katz, Apr 12, 2015.
  1. Anyone have them or can point me to them?
    thanks
  2. DATS V2 reading from the sample. Should be all you need to load into something like WinISD (do so in that order), let me know if you need any of the other numbers:
    Mms: 10.6g
    BL: 7.425Tm
    Cms: 0.313mm/N
    Le: 0.74mH
    Re: 4.986Ohm
    Sd: 107.1cm^2
    Xmax: 3.5mm
    Pe: 150w
    Qms: 6.097
